1995 Mitsubishi Montero no spark
1995 MITSUBISHI MONTERO
SCOTT SWINNEY
Engine Mechanical problem
1995 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic
After engine failure,I replaced fuel pump.
I have found that there is fuel at the engine
but the engine will not fire.
Thanks
Scott, Kimberly Ida.
Jul 30, 2009 at 7:52 AM
Got fuel up to the engine does it have the correct fuel pressure and also is the injector/s pulsing. Do you have spark from the igniton system
Jul 30, 2009 at 9:19 AM
SCOTT SWINNEY
no spark from ignition system
Jul 30, 2009 at 11:09 AM
. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jul 30, 2009 at 12:12 PM
