1995 Mitsubishi Montero Engine loss power
350,000 MILES • 6 CYL • 4WD • AUTOMATIC
BERDY
Dear car owners,
My montero is 95 model, LS type and I am second owner of it. Since 1 year I had no problems but recently the engine check light came on and it seems like one or two of cylinders or spark plugs not working, I replaced with new all spark plugs nothin changed. sometimes for 5 minutes check engine light goes off and engine throttles down as usual, after a while the same light comes out and again the same story again.
what is the exact problem, Did any montero owner solved this problem, please advice.
Thanks in advance
Berdy
Oct 16, 2008 at 5:21 AM
TECHNOPRO
  • 45 POSTS
Hi Berdy,
I think the best way to go is to get the car scanned. We already know here that one of the electronics is not working properly as the check engine light is on.
So a scanning of the computer will give us the fault code.
Cheers
Oct 26, 2008 at 11:10 PM
