1994 Mitsubishi Montero turn signal swtich
12,900 MILES • V8 • 4WD • AUTOMATIC
SHANN
My turn signal only stays on the left side and it just flashes like your going to make a turn, it wont go to the right side. and it will make a buzzing sound. but when i put my hazard lights on the buzzing goes away. so its ether driving with my hazards on or my left turn signal on . I replaced the flasher already. but it still makes that buzzing noise. all the fuses are good also.
Apr 14, 2010 at 2:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
inspect wiring to the signal switch. if wiring is all good then suspect faulty signal (multifunction) switch
Apr 15, 2010 at 3:55 PM
