1994 Mitsubishi Montero DOOR LOCKS
140,000 MILES • V8 • 4WD • AUTOMATIC
PETTEY
I can't open the rear cargo door. The power door locks work but the cargo door handle won't allow me to open the the rear door. I hear and feel the power door lock inside the door when the lock button is depressed, but the handle is loose and doesn't seem to be connnected to the openiing mechanism. I can't find a way inside the door itself to see the mechanism and fix it. My question is ' How do I gain access inside the door to fix it?'
Jun 26, 2010 at 12:02 AM
2CARPRO JACK
  • 11,533 POSTS
When the rear doors wont open, you have to climb in the back and remove the inner panel to gain access to he latch mechanism so you can manually release it. Sometimes if you use a bright flashlight you can possibly look through the holes in the outside handle and see a release rod of some sort that you can maniupulate with a long screwdriver or something to that affect
Jun 30, 2010 at 12:53 AM
PETTEY
I have removed the inside panel, but could not see any unlocking mechanism. Does this model have such a mechanism?
Jul 2, 2010 at 5:53 PM
2CARPRO JACK
  • 11,533 POSTS
They all have a latch of some kind to hold the door shut.Use a bright flashlight and a mirror if need be to look around in the door more
Jul 4, 2010 at 2:05 PM
