1990 Mitsubishi Montero timing.....
1990 MITSUBISHI MONTERO
19,000 MILES • 6 CYL • 4WD • AUTOMATIC
THEWORLEY
i was just wondering if you guys could help me out and tell me how to set the timing on a 1990 montero weve tried using the compression stroke with the cams straight up ,and down weve tried what we thought were built in factory guides and it just wont start .....any info?
May 13, 2008 at 12:13 PM
BLACKOP555
  • 10,386 POSTS
sounds like you should be here
https://www.2carpros.com/kpages/auto_repair_manuals.htm
it is quite a long process to explain how to set the timing, go there they have a wealth of information.
May 13, 2008 at 2:10 PM
