1990 Mitsubishi Montero idle control
250,000 MILES • 6 CYL • 4WD • AUTOMATIC
COOLMASTER
ok my montero has a problem with rpm, when i start the motor the choke run good the problem is when the choke turn off the rpm go up 1500 rpm for 2 seconds and then go to 900 always in parking or neutral , when i put on D on the transmition the rpm are in 1000 and runs good ,i did the timing with the computer jumper in ground
Mar 30, 2008 at 6:34 AM
  • 75,988 POSTS
Is it a Carb or an EFI fuel system?
You probably have a sticking throttle plate/kinked acc. cable or a problem with idle air control valve/motor and the throttle position sensor-
Mar 30, 2008 at 11:33 PM
