Electrical problem
1990 Mitsubishi Montero 6 cyl Four Wheel Drive Manual
I have had a recent tuneup and have a new battery. One day we used the car and it wouldn't start for a long time after we had driven somewhere & got back in to leave...finally it did. Then did it worked ok a few times then it didn't and now it cranks & wont start at all. I notice that the engine continues cranking for a bit even after I release the key & it goes back to run or even off position.
I bought a new ignition switch thinking that MUST be it. That made no difference, so returned the part.
What would make a car continue cranking after releasing the key yet not start? Would a bad solenoid not allow spark to an engine??
Thank you
Thank you
Jun 24, 2010 at 8:40 AM
