fuel pump location
19,000 MILES • 6 CYL • 2WD • AUTOMATIC
IVO295
Well i went to change my battery one day and i accidentally put the wrong cables to the wrong end the positive to positive and negative to negative. After that i heard a little poof sound near the battery maybe it was the fuse but now the car wont start. I tried to jump it or change the battery but nothing. I think the fuel pump went out but where is it located what number/ if not what the problem the relay or the fuel pump???
Aug 19, 2010 at 11:45 AM
  • 75,988 POSTS
Here is a guide to help check the relay and show you step by step how to change out the fuel pump with diagrams below to show you on your car.
and
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Feb 11, 2019 at 10:33 AM
