2000 Mitsubishi Mirage NEW BATTERY
103,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAN DOLE
i am replacing the battery on my 2000 mitsubishi mirage and taking it to get smog check but the mechanic said he cant do it since the battery was replaced I need to follow some steps to set the computer. what does he mean and can anyone explain to me how to reset the computer once I have changed the battery??
Jun 28, 2010 at 1:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If you disconnect the battery then you must drive the vehicle to enable the engine control module (ECM, or computer) to relearn driveability. This is normally a set amount of miles, to get the exact mileage to relearn the ECM driveability, contact your local Mitsubishi dealer.
Jun 30, 2010 at 3:57 AM
