2000 Mitsubishi Mirage Mitsubishi mirage engine vibrated?
44,125 MILES • 4 CYL • FWD • AUTOMATIC
PALVAN
Hello.mi name is paul,I got a problem with my car.u see the engine vibrated,when is in park,in reverse,neutraland even in drive?The engine already have new mounts engine,spark plugs+wires,the entire distributor,new timming bell.Even I take to the mitsubishi and they said it was the head cilynder 2 valves burn it,,they change it, but the engine still vibrate u can fell it inside of the dashboard,stering wheel,etc,,I told them that is not normal,so they said is normal,What can I do?How can I fix?is something simple to fix,please help me..thans paul.
Apr 13, 2009 at 5:54 AM
KHLOW2008
  • 41,812 POSTS
Hi Paul,
Thank you for the donation.
This is something that is not going to be easy to diagnose online as we do not understand the extent and source of the vibrations.
If the engine is running smoothly, then it should be external.
When does the vibration occurs?
With AC turned ON?
With gears in D or R?
You mentioned the engine mounts are new, did you check the installation?
Did you check if the central crossmember is bent?
Jan 20, 2010 at 12:31 AM
