2000 Mitsubishi Mirage Headlight Bulbs
2000 MITSUBISHI MIRAGE
COFFEE4ME
Electrical problem
2000 Mitsubishi Mirage 4 cyl Front Wheel Drive Automatic
How do you change the headlight bulbs in a Mitsubshi Mirage 2000
Oct 13, 2010 at 7:50 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_2000_mitsu_mirage_head_light_bulb_part_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_2000_mitsu_mirage_head_light_bulb_part_2_1.jpg
BULB REPLACEMENT 1. Disconnect the connector. 2. Remove the socket cover. 3. Unhook the spring securing the bulb, and then remove the bulb. CAUTION: Do not touch the surface of the bulb with hands or dirty gloves as the bulb may pop after a short time. If the surface does become dirty, clean it with alcohol, and let it dry thoroughly before installing. There you go.
Oct 13, 2010 at 8:26 AM
