2000 Mitsubishi Mirage car starting and then not starting b
133,000 MILES • 4 CYL • 2WD • AUTOMATIC
LLABOMBARDA
OK so my car will start, after it has been sitting for a least 2 hours. Yesterday I drove 10 miles, and not very quickly. turned off my car and it would not start back up for 2 hours. Of course the radio and lights come on when i attepmted, but there is not even a clicking noise when this happens. I think my lights come on fine and what not. So I have no idea what to do which this thing. Please help!
Apr 2, 2010 at 1:25 AM
SAVI2010
[quote:c7b1df5a4b="llabombarda"]Electrical problem
2000 Mitsubishi Mirage 4 cyl Two Wheel Drive Automatic 133000 miles
OK so my car will start, after it has been sitting for a least 2 hours. Yesterday I drove 10 miles, and not very quickly. turned off my car and it would not start back up for 2 hours. Of course the radio and lights come on when i attepmted, but there is not even a clicking noise when this happens. I think my lights come on fine and what not. So I have no idea what to do which this thing. Please help![/quote:c7b1df5a4b]
Check the ignition switch. its located in the steering column and it is connected to the key socket. The part is known to go bad and it usually effects the entire electrical system. Also, check under the steering wheel behind the plastic cover to see if any wires are disconnected. A small wire came apart as i was driving my mirage and it shut the whole car down. ill see if i can find a pic to add of the ignition switch. i changed the part in my car by myself.
Apr 8, 2010 at 4:46 AM
