1998 Mitsubishi Mirage turn signal switch
1998 MITSUBISHI MIRAGE
BACON21
  • 10 POSTS
Electrical problem
1998 Mitsubishi Mirage 4 cyl Front Wheel Drive Automatic
I would like to know the procedure to replacing a turn signal with in my car.
Jul 13, 2010 at 10:00 AM
RICHZOMBIE
  • 173 POSTS
Replacing the turn signal switch involves replacing the entire turn signal assembly. Remove the screws from the steering column cover to remove the top of the steering column. You can take off the bottom (you may be able to work around it). There are only a few screws holding the turn signal assembly. Remove the screws and unfasten the electrical connectors.
Jul 13, 2010 at 10:12 AM
