1998 Mitsubishi Mirage Code P300
1998 MITSUBISHI MIRAGE
140,000 MILES • 4 CYL • FWD • AUTOMATIC
ARCH7ANGEL
  • 5 POSTS
For about 6 months now I keep getting code P300, multiple cylinder misfire. At one point I had the code for Cylinder 2 misfire and that one has cleared now. The only problem I have had with the car is it bucks for a few seconds after I stop and start again. It also has trouble accelerating. I have replaced the spark plugs, wires, distributer and cap. Recently I changed the injectors. Nothing is clearing this code. A few times I used the injector cleaned fluid and for a week or two I had no problems, but than the car starting bucking and having trouble accelerating. Any ideas on what could be causing this?
Jun 1, 2010 at 7:28 AM
A P0300 Random misfire is normally caused by vacuum leaks and bad fuel
Jun 1, 2010 at 9:24 AM
ARCH7ANGEL
  • 5 POSTS
i have changed the fuel filter and i use the middle grade of gas, and almost always from the same gas station. how do you know if it is bad gas? and we did a qucik check for vacuum leaks and there weren't any.
Jun 1, 2010 at 11:58 PM
ARCH7ANGEL
  • 5 POSTS
Thanks. I just changed spark plugs for cylinder 2 and 3 and its working a lot better. I had the CEL cleared after this too. but yesterday it bucked twice and the CEL came on again. But other than that, the car has been running much smoother.
Jun 3, 2010 at 12:05 AM
ARCH7ANGEL
  • 5 POSTS
like i said at the beginnig, we did all the normalr replacements. the spark plugs, wires, cap and rotor. but since it changed after swapping wires around, i went a bought new wires and plugs. the car is running better than i remember when i bought it.
Jun 9, 2010 at 5:19 AM
