1997 Mitsubishi Mirage the car is bogging what is the probl
JAYTISH
Engine Performance problem
1997 Mitsubishi Mirage 4 cyl Two Wheel Drive Automatic
i tried to clean the spark plug don't work change the fuel don't work?
Dec 21, 2009 at 8:53 PM
  • 75,988 POSTS
Oygen Sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Dec 22, 2009 at 7:17 PM
JAYTISH
okay i'll try that and if still don't work i'll send a message
Dec 22, 2009 at 11:04 PM
