1995 Mitsubishi Mirage Where is the fuel pump/relay fuse
1995 MITSUBISHI MIRAGE
80,000 MILES • 4 CYL • 2WD • MANUAL
MITSUBISHI 95
My car does not start, starter and battery both in good condition. Want to check 1st if the fuse is good or bad.
Mar 12, 2009 at 5:02 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 12, 2009 at 5:08 PM
