1995 Mitsubishi Mirage a/c
GAMEZ69
Electrical problem
1995 Mitsubishi Mirage 4 cyl Front Wheel Drive
every time i turn on A/C it blows the 10amp fuse?
Jun 28, 2010 at 6:41 AM
SATURNTECH9
  • 30,869 POSTS
Unplug the a/c compressor and replace the fuse then turn the a/c back on did the fuse blow?
Jun 28, 2010 at 7:03 AM
GAMEZ69
yes it did (10amp) and now it blew the aux radiater fan fuse(30amp square one) cause when the a/c used to turn on it would turn on the 2nd fan too.
what wrong? what about 20amp relay A/C next to it?
Jun 29, 2010 at 3:13 AM
SATURNTECH9
  • 30,869 POSTS
[quote:12d1d9c35d="gamez69"]yes it did (10amp) and now it blew the aux radiater fan fuse(30amp square one) cause when the a/c used to turn on it would turn on the 2nd fan too.
what wrong? what about 20amp relay A/C next to it?[/quote:12d1d9c35d]
OK for your 30 amp fan fuse you have a bad fan motor or a short to ground in the fan circuit some where.Also it sounds like you have a short in the a/c clutch circuit to ground.They could be shorted in the same place.Ok on the 30 amp fan fuse where the fuse goes in you will have a power side and a circuit side with the fuse out find the side that doesn't have power.Now check that side for a short to ground.On the a/c fuse do the same.
Jun 29, 2010 at 7:37 AM
