1995 Mitsubishi Mirage 95 Mirage wont start
DHAWTHORNE15
1995 Mitsubishi Mirage 101000 miles
I have a 95 Mitsubishi Mirage that I just bought yesterday that test drove fine but when I got it home I couldnt get it started again. It has gas, timing belt is in place and I can hear the fuel pump go after I let go of the key. The engine will turn but wont fire. I didnt drive it home from the lot, I had a tow truck to bring it to my house.
Aug 23, 2009 at 1:14 PM
  • 75,988 POSTS
Check the fuel pressure with a gauge and also for injection pulses-if okay check for spark
Aug 23, 2009 at 1:17 PM
DHAWTHORNE15
How do I check fuel pressure? This will be my first time doing it.
Aug 23, 2009 at 3:17 PM
  • 75,988 POSTS
You need a fuel pressure tester designed for your fuel system If there's no test port, remove the fuel filter and check it there.
Aug 23, 2009 at 5:24 PM
