1992 Mitsubishi Mirage High idle
PETERELLO
Engine Performance problem
1992 Mitsubishi Mirage 4 cyl Front Wheel Drive Manual
The engine is fuel injected. When started it revs at 3000rpm untill warm. It also revs at 3000rpm when the aircon kicks in. I know the revs usually increase a bit when aircon is on but this is excessive. What could the problem be.
Sep 30, 2009 at 4:40 AM
LEGITIMATE007
  • 5,121 POSTS
sounds like the idle speed motor may need to be replaced, also a throttle body cleaning may be in order for good measure
Sep 30, 2009 at 7:08 AM
