1992 Mitsubishi Mirage FUSE BOX
GIDDY
  • 5 POSTS
Electrical problem
1992 Mitsubishi Mirage 4 cyl Front Wheel Drive Automatic
I am going to upload the photo of my fuse box inside my car. Can someone please confirm the year of the car for me and if they have the english translation for the chineese or japaneese description.[img:2e30430ca9]http://www.2carpros.com/forum/automotive_pictures/562350_IMG_0205_1.jpg[/img:2e30430ca9][img:2e30430ca9]http://www.2carpros.com/forum/automotive_pictures/562350_IMG_0204_1.jpg[/img:2e30430ca9]
Aug 17, 2010 at 9:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the year of the car should be in the driver's door jamb, on the title and could even be looked up on the internet using your VIN..would be hard to say what year it is just from a fuse box .. i do believe that is newer than a '92 though. give me the VIN and i can look it up for you and post the correct fuse layout.
Aug 17, 2010 at 9:54 AM
GIDDY
  • 5 POSTS
The chasis number E-CB3A PRPM ENGINE 4G91 PART# FOR FUSE BOX: MB852914 PHOTO OF CAR ATTACHED
https://images.2carpros.com/forum/automotive_pictures/562350_MIRAGE_CLIP_SIDE_1.jpg
Aug 17, 2010 at 10:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
that chassis number is from a 1991, although the 91 and 92 used the same parts...the pic of your fuse box just doesn't match the diagram I have for the 89 - 92 mirage's fuse box. it looks as though this is the fuse box under the drive dash, right? here is the diagram and legen I have for the 89 - 92 mirage..
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_655.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2591.jpg
Aug 17, 2010 at 10:34 AM
GIDDY
  • 5 POSTS
Yes this is the fuse box below the steering. but in comparision to your diagram my box have more slots. Can you direct me to some where or someone who may have the identical box please. I have been trying on this car for a while now please
Aug 17, 2010 at 10:42 AM
KHLOW2008
  • 41,812 POSTS
Blow up the Japanese wordings on the fuse box cover and let me see if I can get the translation done for you.
Aug 18, 2010 at 3:22 AM
GIDDY
  • 5 POSTS
I am going to send you a photo of the fuse box cover. You can magnify and let me know if you can decipher. If not will send another photo
https://images.2carpros.com/forum/automotive_pictures/562350_IMG_0206_2.jpg
https://images.2carpros.com/forum/automotive_pictures/562350_IMG_0206_1.jpg
Aug 18, 2010 at 5:34 AM
KHLOW2008
  • 41,812 POSTS
Sorry, the image did not show up well. At 200 % it is to small, at 400% the wordings becomes blur. Your picture is upside down so I have flipped it over for you. I have attached a table for the Japanese characters. Starting from left, number them 1 to 7 for first column, 8 to 16 for second column and 17 to 21 for the last column. Use the table as a guide and list each of the characters as they are written with the Katakana table and I will get them for you. eg 1. ra ji o If you wish to post the photos, try dividing into 2 or four parts so that the closeup would be clearer.
https://images.2carpros.com/forum/automotive_pictures/192750_FuseBox562350_IMG_0206_2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_KatakanaTable01_1.jpg
Aug 19, 2010 at 1:50 AM
