i have a 1990 mirage 1.5 MPFI.
engine quit on me a few weeks ago while running interstate speed (75mph) would not refire. had it towed home pulled the #1 plug and checked for fire there was non. i pulled the ECU and sent it to AUTOMOTIVE COMPUTER SUPPLY ,Huston Texas.
i had the ECU fail back in 2005 and it was the problem. this is not the case this time. i spoke to the tech and he said there was nothing wrong with my ECU.
I changed the coil installed a new distributor, distributor cap, rotor and wires but still no fire. timing belt has about 40,000 miles on it and timing is good. I assume the cam positioning sensor is built into the distributor because i didn't see one on anywhere on the cam.
i can hear the fuel pump relay and hear the fuel pump run when i try to crank it.
Dec 22, 2009 at 4:16 AM
