1993 Mitsubishi Magna Radiator
RUPERTMARKLEW
Engine Mechanical problem
1993 Mitsubishi Magna 6 cyl Front Wheel Drive Automatic
The fans for the radiator have stopped working, this causes the engine to cut out if driven too long.
Feb 26, 2010 at 12:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check the fuse(s) for the fans. also check cooling fan relay(s). if OK then check for faulty engine coolant temp. sensor.
Feb 26, 2010 at 12:32 PM
