2008 Mitsubishi Lancer Evolution High engine oil pressure
21,000 MILES • 4 CYL • AWD • AUTOMATIC
WILLIAMJOHN
Recently the transmission was changed at the dealership. In the last week engine oil has been spewing past the oil filter gasket or in one case the oil filter actually expanded and released oil past the oil filter gasket. OEM filters are being used. This is the third oil filter that this has happened with.
It appears that there is too much oil pressure.
Any thoughts?
Thanks
Bill
Oct 15, 2010 at 3:26 AM
  • 75,988 POSTS
Check the oil pump pressure relief valve might not be opening
Oct 15, 2010 at 3:31 AM
