2004 Mitsubishi Lancer
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
YINKEBO
  • 34 POSTS
Scanned car and called two codes
1. P0442
2. P0183
Don't know what to do?
I have erased it to check if it will re-appear
Dec 3, 2009 at 5:27 PM
  • 31,937 POSTS
Hi there, these codes refer to the evap system (minor leak) and a fuel temp sensor. if the codes re set, have the evap system check this may be a minor vacuum leak, and the second problem will need to tracked down by an auto electrician.
Mark (mhpautos)
Dec 3, 2009 at 6:14 PM
YINKEBO
  • 34 POSTS
this evap, where is the position on the car?
the fuel temp. sensor, where is the position as well? I may be able to check if the fault is electrical because I am an electrical engineer. It could be lost of continuity on the cable
Dec 3, 2009 at 6:42 PM
  • 31,937 POSTS
Hi there, See pics for sensor & evap systems. Mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_128.jpg
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic1_6.jpg
Dec 3, 2009 at 7:43 PM
YINKEBO
  • 34 POSTS
Thank you for the picture but it too tiny and I cannot read what is written on
Dec 3, 2009 at 8:32 PM
YINKEBO
  • 34 POSTS
hi there,
Please what is the implication of these faults on the car?
Dec 3, 2009 at 9:49 PM
  • 31,937 POSTS
Hi there,
you will not pass the smog test if you are required to have one annually, you may have a few issues with fuel economy as well.
Mark (mhpautos)
Dec 4, 2009 at 1:13 PM
