2002 Mitsubishi Lancer TRANSMISSION PROBLEM
13,000 MILES • 4 CYL • FWD • MANUAL
JERRYHAHIN
While driving to work this morning, my transmision suddenly failed to engage. It would not engage in any gear. Prior to this, I noticed in each gear the engine rev rate was very high (not in the red zone though) as I was accelerating in eahc gear. The car qit engaging at a stop sign and when I exited the car and lifted the hood I could smell something burnt. Ther was not noticable smoke or any other indication of a problem. Is this my whole transmission, clutch or what has happened?
Jun 11, 2008 at 1:04 AM
KHLOW2008
  • 41,812 POSTS
Hi JERRYHAHIN,
The smell was probably from the trans.
The ATF level must have been low which caused the slipping.
If you are lucky, there might be a leakage with the hoses and the fluid got dry. Fixing the leak and adding ATF might solve the problem.
Otherwise you need to rebuild the trans.
Jun 11, 2008 at 2:06 AM
