2002 Mitsubishi Lancer spark plugs
GCARPENTER70
  • 2002 MITSUBISHI LANCER
  • 4 CYL
  • 170,000 MILES
I wanted to know how to change the spark plugs on my 2002 Mitts Lancer.
Monday, March 15th, 2010 AT 4:45 PM
SPARK PLUG CHECK AND CLEANING
1.Check that the plug is not burned, that the insulator plug is not damaged, and that the seizure state is good.
2.If cleaning is required due to carbon deposits, etc., clean using a plug cleaner or wire brush, etc.
3.Check the plug gap using a plug gap gauge, and adjust if not within the standard value. Standard value: 1.0 - 1.1 mm (0.039 - 0.043 inch)
SPARK PLUGS (REPLACE)
Spark Plug Type
https://www.2carpros.com/forum/automotive_pictures/12900_spt_1.gif
1.Spark plugs must spark properly to assure proper engine performance and reduce exhaust emission level. Therefore, they should be replaced periodically with new ones. Few the list below:
https://www.2carpros.com/forum/automotive_pictures/12900_spg_1.gif
2.The new plugs should be checked for the proper gap. Spark plug gap: 1.0 - 1.1 mm (0.039 - 0.043 inch)
3.Install the spark plugs and tighten to 25 N.m (18 ft-lb)
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Monday, March 15th, 2010 AT 6:31 PM
