2002 Mitsubishi Lancer Crank pulley
2002 MITSUBISHI LANCER
KOROCARE
Engine Mechanical problem
2002 Mitsubishi Lancer 4 cyl Front Wheel Drive Automatic
What direction do I turn the bolt(22mm) to loosen it?
Jul 11, 2009 at 7:23 PM
  • 31,937 POSTS
Hi there,
This is a standard R/H/Thread, it will be very tight, you may need to remove the starter and lock the flywheel with a lever to stop the engine turning.
Mark (mhpautos)
Jul 11, 2009 at 7:26 PM
