1994 Mitsubishi Lancer CODE 41
LANCER GLXI
Electrical problem
1994 Mitsubishi Lancer 4 cyl Two Wheel Drive Automatic 100,++ miles
the check engine llights up if rpm drops below 1000rpm at start up . if i maintain it at above 1000 rpm it would not light up. Had it checked and diagnostics showed code 41 fuel injector.
had the injectors cleaned but the problem persists.
any sugestions?
Jun 18, 2008 at 10:48 PM
KHLOW2008
  • 41,812 POSTS
Hi LANCER GLXI,
I doubt cleaning the injectors would help.
It is the injectors circuit problem, you need to check the electricals, open or short circuit.
Jun 21, 2008 at 11:28 PM
