1993 Mitsubishi Lancer pls help..
1993 MITSUBISHI LANCER
170,000 MILES • 4 CYL • FWD • MANUAL
IVAN_12
hi, i have a 1993 mits lancer, 4g15(efi) engine.. it is emitting a white smoke in its tailpipe, my sparkplug is always wet with oil, and recentlly I notice that oil is being discharge thru the air inlet going to the intake manifold in the EFI via a hose in the overhead top cover.. pls help, i dont know whats the problem with my car.. thanks..
Oct 26, 2010 at 10:22 PM
Check if the headgasket is blown or the head is cracked or block and also check the PCV valve
Oct 27, 2010 at 3:50 AM
