1996 Mitsubishi L200 Engine cranks but does not start
1996 MITSUBISHI L200
200,000 MILES • 4 CYL • 2WD • MANUAL
MIHIRISAMPATH
Engine cranks but does not start.battery is ok.seems fault with fuel priming pump.after priming several times it starts and it starts with a little push.pl answer
Nov 30, 2009 at 2:31 PM
  • 31,937 POSTS
Here,
I would start with getting the fuel pressure tested, replace the fuel filter, do a general tune up and check the ECU for any unresolved fault codes, start here.
Mark (mhpautos)
Nov 30, 2009 at 2:49 PM
