1985 Mitsubishi L200 NO engine oil pressure
DAZZLER 12
Engine Mechanical problem
1985 Mitsubishi L200 4 cyl Four Wheel Drive Manual 67000k miles
Engine has lost oil pressure. Was driven for 20km, stopped, then when restarted had no oil pressure at all. Engine was rebuilt 67000km prior. Have 15 years history of vehicle. Oil & filter changed 100km prior. Strip down & full inspection of oil pump, pickup, filter, bearings, releif valve, gaskets, has revealed no reason for loss of oil pressure. The internals are as clean as a new car off the production line. What am i missing? What else could cause this situation? We are going to reassemble with new oil pump, releif valve & spring, even though they all appear in good working order. Any ideas would be appreciated.
Feb 19, 2009 at 10:01 AM
  • 31,937 POSTS
Hi there.
The only other thing is make sure that the oil pick up is not cracked and sucking air, prime the new pump and back fill the oil fitter remove the spark plugs and crank over to raise oil presser before you start it up.
Mark (mhpautos)
Feb 19, 2009 at 12:14 PM
