2006 Mitsubishi Galant No brake lights
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
MIKED11_2007
None of the brake lights are working on my 2006 mitsubishi galant. I changed both bulbs . I checked brake switch with an ohm meter. I checked all the fuses. Do the brake lights operate through one of the omron relays? If so, which one? If not, what else should i do?
Apr 15, 2010 at 11:04 AM
  • 75,988 POSTS
Do you have power at the green and black wire on the brake switch connector? If not check fuse no.11 15amp
Apr 15, 2010 at 11:23 AM
MIKED11_2007
I would have thought the brake light fuse would have been under the dash. Not under the hood in the relay box but there it was. All fixed. Thanks.
Apr 15, 2010 at 11:45 AM
