2005 Mitsubishi Galant brake lights
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
CUTEYGAL
how do you repair brake lights even changing and checking bulbs and fuses didn't work.
Oct 21, 2009 at 4:41 PM
  • 31,937 POSTS
Hi there,
You will need to check the brake light switch which is located at the top of the brake pedal under the dash, there are 2 wires you should have power at one and power at the other with the pedal pushed down, check that next.
mark (mhpautos)
Oct 21, 2009 at 5:13 PM
