2004 Mitsubishi Galant power steering fluid leak
2004 MITSUBISHI GALANT
55,000 MILES • 4 CYL • FWD • AUTOMATIC
MANGO79
I have to refilll pwer steering fluid quite often. What can I do.
May 26, 2008 at 11:14 AM
  • 31,937 POSTS
Hi there,
You will have to identify where the leaks is coming from, either the pump, rack or hoses. Wash down and inspect when running, if the rack you will be better of having your mechanic replace it. The pump & hoses are some hat easier if you have some mechanical skills.
mark (mhpautos)
May 26, 2008 at 10:23 PM
