2004 Mitsubishi Galant Engine Shakes while Idle
2004 MITSUBISHI GALANT
43,000 MILES • 4 CYL • FWD • AUTOMATIC
DEEPBLUESEA1226
  • 7 POSTS
Hi, guys.
I have a Mitsubishi Galant 2004, I have change the sparks plugs to fusion bosch, but for some reason the engine shakes while the car is in park position. do you guys know what should I do to correct the problem.
thank you very much
Feb 18, 2010 at 10:51 PM
  • 31,937 POSTS
Hi there,
best first check the engine compressions, no use doing a tune if the comps are low... also get a scan done to check for any unresolved fault codes, start here.
mark (mhpautos)
Feb 18, 2010 at 10:56 PM
DEEPBLUESEA1226
  • 7 POSTS
Thank you for replying.. Is it possible to check the engine compression by my self or do I need to bring to dealer to check?
Feb 19, 2010 at 4:18 PM
  • 31,937 POSTS
Hi there,
This is a simple job but you do need a comp tester, do you have one? let me know and i will talk you through the process.
mark (mhpautos)
Feb 19, 2010 at 4:25 PM
DEEPBLUESEA1226
  • 7 POSTS
I don't have the tester, please talk me through it.
thank you very much
Feb 19, 2010 at 4:38 PM
  • 31,937 POSTS
Hi there,
Warm up the engine, remove spark plugs, number leads so as not to mix them up, remove coil lead from distributor and earth, fit comp tester into spark plug hole (they normally screw in) with full throttle crank engine over 2-3 revolutions, note down comp with Cyl no, re set comp gauge to zero remove and fit into next cyl, do same as first. do all 4 and report comps here, you can do this twice with a little oil in the cyl this is a wet test do this after the dry test and compare wet & dry readings of each cylinder, this is what i need to know...
mark (mhpautos)
Feb 19, 2010 at 7:16 PM
