2004 Mitsubishi Galant EGR insufficient flow.
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
GLENNHBK
I have a 2004 Mitsubishi Galant 6 cylander, which is stopping whenever the rpms get below 1000. It starts fine after stalling, and it stays on while the rpms are above 1000. It has a check engine message that says "exhaust gas recirculation flow insufficient detected." What is a good price for a replacement, and would it work to jus clean this out?
Dec 28, 2009 at 9:52 AM
  • 75,988 POSTS
P0401
Try cleaning it out and make sure its getting vacuum if its vac operated
Dec 28, 2009 at 10:50 AM
PETERRABIT76
[quote="glennhbk"]Engine Performance problem
2004 Mitsubishi Galant 6 cyl Two Wheel Drive Automatic 110000 miles
just take the EGR out and cleaning it with brake cleaner or degreaser a lil, its just carbon build up.. i had that same problem on my 4cyl. easy fix... and its one of the most expensive parts to replace on the galant. make sure to replace the gasket first before re-installing
Feb 2, 2010 at 10:06 PM
