2004 Mitsubishi Galant accessory outlet not working
94,000 MILES • 6 CYL • FWD • AUTOMATIC
KB13
My accessory outlet is not working, but the fuse listed for the outlet is not blown. Is there another fuse I should be looking for? Car has 2 outlets, only 1 is not working. Where else should I look?
Feb 20, 2010 at 11:40 PM
INDAGO1987
  • 7 POSTS
[quote:82e99e05fa="kb13"]Electrical problem
2004 Mitsubishi Galant 6 cyl Front Wheel Drive Automatic 94000 miles
My accessory outlet is not working, but the fuse listed for the outlet is not blown. Is there another fuse I should be looking for? Car has 2 outlets, only 1 is not working. Where else should I look?[/quote:82e99e05fa]
The socket itself could be fried. Try replacing the accessory socket. I blew both my cigarette lighter and accessory socket last year. I went to the junkyard to get a replacement assembly, installed it, and replaced the fuse. Only after I did all that, did I successfully fix it. I can give you instructions on how to remove and install the piece if you pm me.
Mar 14, 2010 at 5:03 PM
