2003 Mitsubishi Galant POWER WINDOWS
2003 MITSUBISHI GALANT
75,000 MILES • 4 CYL • FWD • AUTOMATIC
MRCARTER21237
I can control all the windows accept the front passenger from the driver's main control. I then tried to use the passenger side control to open the window without any success. Can you please tell me what is the probllem?
thanks
gordon
Mar 19, 2009 at 4:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
First you need to inspect your fuses as a precaution. If OK, check power to the window motor for the suspect window. If power is to motor, suspect faulty window motor. If no power then need to trace wiring to inspect for shorts/open circuits. Post results and I will follow up.
Thanks for using 2CarPros.com !
Mar 19, 2009 at 6:19 PM
