2003 Mitsubishi Galant p0340/p0335
TROY96792
  • 7 POSTS
Computer problem
2003 Mitsubishi Galant 6 cyl Front Wheel Drive Automatic
Can you help me? I am helping a friend with his car. I scanned the car and the scanner picks up a p0340/p0335 camshaft position sensor and crankshaft postion sensor codes. He replaced the crank sensor. but it still runs rough and doesnt idle. Also, Mitsubishi dealer claims there is no cam sensor.
Do you think the pcm needs reprograming?
thanks in advance
Apr 16, 2008 at 8:01 PM
TROY96792
  • 7 POSTS
[quote:ba77d54c04="troy96792"]Computer problem
thanks in advance[/quote:ba77d54c04]
Can anyone answer my questions? How much donation do i need to make before I get a correct response? Is it that hard of a question, or do you guys only answer easy ones..let me know. Thanks in advance.
Apr 21, 2008 at 1:23 PM
GALANT 02
the camshaft sensor is behind the timeing belt on my 2002 mitsubishi galant i have a 4 cyl thats where my mech said mys was at i hope that helps you
May 5, 2009 at 12:53 PM
