2003 Mitsubishi Galant Leaks, leaks, leaks
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
IAMZBOB
Hi, got a 03 galant se. Started with radiator cap melting down into radiator. Since then we are on our third water pump in 4 months. the mechanic is stumped mad and tired of replacing them. What could cause this?
Jun 23, 2009 at 5:04 AM
DER
  • 6 POSTS
have you tried flushing the cooling system and see if their is something you could put in there to clean it out
Jun 25, 2009 at 3:25 AM
IAMZBOB
the entire system was flushed at each water pump change.
Jun 27, 2009 at 12:28 AM
