2003 Mitsubishi Galant any body help me on this galant
138,255 MILES • 4 CYL • FWD • AUTOMATIC
NOOR_HAWAMDEH
  • 10 POSTS
hello expert
i have mitsubishi galant lately i've experienced an un burned fuel (gasoline) from exhaust with a high fuel consumption
i changed the spark plg,coils, but still the same
lately a friend adviced me to check it by 4 gas analyser but no body tell me what this reradings mean:
co=1.5 co2=13 hc=225 PPM o2=0.5 lamda=0.989
from this readings do any one tell me what is the problem with my car?
thank u
Sep 19, 2008 at 10:43 PM
  • 75,988 POSTS
Carbon monoxide is on the border line and Hydrocarbons high
For a start get the catalytic converter checked out
Sep 19, 2008 at 11:33 PM
NOOR_HAWAMDEH
  • 10 POSTS
[quote:26dead6bc9="rasmataz"]Carbon monoxide is on the border line and Hydrocarbons high
For a start get the catalytic converter checked out[/quote:26dead6bc9]
dear expert i got a new catalyser from it agency its a new one
Sep 20, 2008 at 12:38 AM
  • 75,988 POSTS
Hydrocarbon failures mean unburned gasoline is passing through the engine and entering the exhaust. The three most common causes include ignition misfire, lean misfire and low compression (typically a burned exhaust valve). Ignition misfire can be caused by worn or fouled spark plugs, bad plug wires or a weak coil. Lean misfire results where there is too much air and not enough fuel, so check for vacuum leaks, dirty injectors or a fuel delivery problem. In addition to these, hydrocarbon failures can also be caused by oil burning due to worn valve guides, valve guide seals and/or rings.
Sep 20, 2008 at 6:10 AM
