2003 Mitsubishi Galant A/C makes clicking noise even off (i
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRESICK
Hi, my mitsubishi galant 03 has a funny problem.
It makes a clicking sound when I put the temperature knob in the coldest setting. It does so even if the fan is turned off. Any ideas on why this happens?
Other than that the a/c appears to work fine and the air comes really cool.
Changing the knob that marks were the air will come out from doesn't seem to make a difference.
Thanks!
Nov 30, 2008 at 4:05 PM
JAMES W.
  • 2,394 POSTS
Does the "clicking" speed up with engine speed? Looking at the ac compressor clutch, is there a piece of the clutch hanging out? Please advise.
Dec 1, 2008 at 5:08 AM
BRESICK
There doesn't seem to be anything out of place or hanging near the compressor.
The clicking starts slowly when I turn the ignition key without starting the engine. If i turn on the engine it picks up pace and even more if I accelerate the car.
I've also noticed the air isn't blowing so cold anymore.
I'm pretty sure I've located the origin of the clicking sound. It comes from inside the car cabin, near the a/c controls and not anywhere close to the engine.
Thanks for the help. :)
Dec 1, 2008 at 3:19 PM
JAMES W.
  • 2,394 POSTS
Sounds like you have something in the blower fan for the heater/ac. You may want to check that out.
Dec 1, 2008 at 5:18 PM
GRINSTEINNER
I'm having the same problem with my 03 Galant. I was curious if you ever figured out what was wrong with yours?
Jan 25, 2009 at 2:24 AM
