If your car is blowing air but it is cold air, check the anti-freeze level and make sure the temp. Gauge isnt in the red zone. If it is, the Thermostat needs to be replaced, or your head gasket is blown. Also, check the fuse panel box for blown fuses or relays. If not the case, you need a new Heater Blower Motor.
SPONSORED LINKS
Thursday, January 7th, 2010 AT 11:02 PM
