2002 Mitsubishi Galant squealing belt (s)
2002 MITSUBISHI GALANT
130,000 MILES • 4 CYL • FWD • AUTOMATIC
GABELEON
I recntly moved from Miami, Fl to Los Angeles. I knew i would be driving so I decided to replace my timing belt. While I did that I replaced the water pump, balance belt, alternator and drive sorpentine belts. 5 days after it started to squeal so I took it back to mechanic. He had no problems tightening or loosening belts. Which he said was the issue. Unfortunately I no longer live in Miami. What are my options????
Jul 26, 2010 at 5:33 PM
If the squealer got fixed right then and there no complaint by you prior to you departing to Cali-you just have to bite the bullet here-Now that you're there get it checked could be loose again or whatever the case may be
Jul 26, 2010 at 7:42 PM
