2002 Mitsubishi Galant power window
58,000 MILES • 4 CYL • FWD • AUTOMATIC
TINDMAC
My driver side power window will not go up or down. I hear the window motor running and can raise and lower the window by pulling up on it. What do you think is wrong?
Jan 29, 2009 at 9:44 AM
DON OLIVER
  • 101 POSTS
the window lift mechanism if stripped or broken. another possibility is the window has come undone from the lift mechanism. remove the door panel and see whats going on? make your repairs as needed
Jan 29, 2009 at 9:59 AM
