DEAR EXPERT LOOKING FORWARD TO HELP ME
I HAVE MITSUBISHI GALANT 2002 A/T AND THE CHECK ENGINE LIGHT ON (SYMPTOM: ENGINE STALL)
THE DTCs ARE
CODE NO 44 IGNITION SIGNAL 1
CODE NO 14 TPS ABNORMAL ADJ
CODE NO 22 ABS SENSOR SHORT
I NEED THE DIAGNOSTIC TROUBLESHOT PROCEDURE?
WHICH DTC I HAVE TO WORK ON IT FIRST TO SOLVE THE PROBLEM?
DOES THE ABS CAUSE THE ENGINE STALL? (I GUESS NOT) BUT THIS GALANT IS DRIVING ME CRAZY!!!!
more over while driving with the transmission on D the symptom doesnt occure but once when u shift on L2 or L1 with load the symptom occures
i need your help on that plz
THE DTCs ARE
Jul 7, 2008 at 8:12 PM
