Transmission service
NRH_123
  • 8 POSTS
I noticed a little slipping in my transmission today. I checked the fluid level and the fluid is dark. Looks like it needs changing. First of all, would that cause slippage? Second of all what type of fluid does my car take? Is there a drain plug? Do I need to change the filter and if so, where is it?
Jun 9, 2010 at 1:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Did you notice metallic flakes and/or burning smell from the fluid? If so than that would indicate internal failure in the tranny somewhere. If it's just dark then it's dirty and needs replaced, it may or may not be the cause of slipping. To replace it you would have to disconnect a hose from the tranny and let it drain out of it by starting engine and put in Neutral. After that, remove the drain plug from bottom of transaxle case to get the rest to drain.
This guide will help walk you through the steps
Fluid Types
AUTOMATIC TRANSAXLE
LUBRICANTS
A/T fluid .................... DIAMOND ATF SP III or equivalent
Capacities
AUTOMATIC TRANSAXLE
LUBRICANTS
A/T fluid L (qt) .................... 7.8 (8.2)
Jun 9, 2010 at 1:47 PM
NRH_123
  • 8 POSTS
[quote:67ba8bf38b="bluelightnin6"]Did you notice metallic flakes and/or burning smell from the fluid? If so than that would indicate internal failure in the tranny somewhere. If it's just dark then it's dirty and needs replaced, it may or may not be the cause of slipping. To replace it you would have to disconnect a hose from the tranny and let it drain out of it by starting engine and put in Neutral. After that, remove the drain plug from bottom of transaxle case to get the rest to drain. Use DIAMOND ATF SP III or equivalent[/quote:67ba8bf38b]
Who carries this ATF SP III?
Jun 11, 2010 at 3:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
get it from a Mitsubishi dealer or can substitute with DEXRON III or Mopar ATF+4
Jun 11, 2010 at 3:45 PM
NRH_123
  • 8 POSTS
[quote:96859f45d9="bluelightnin6"]get it from a Mitsubishi dealer or can substitute with DEXRON III or Mopar ATF+4[/quote:96859f45d9]
You're sure about the Dexron III, right? When I called Mitsubishi, the fella tried to sell me a quantity of ATF under the brand name Bully Bull Dog and said it ran $49. Interesting enough, when I pressed him, he couldn't give me the type of tranny fluid it was. I thought that sort of suspicious. So anyhow, Dexron III will do the trick?
Jun 11, 2010 at 3:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yep i'm certain
Jun 11, 2010 at 4:13 PM
NRH_123
  • 8 POSTS
[quote:f8bba45d31="bluelightnin6"]yep i'm certain[/quote:f8bba45d31]
Well, in that case, thank you in advance.
Jun 11, 2010 at 11:34 PM
