2002 Mitsubishi Galant
BABYGIRL_7_10
Electrical problem
2002 Mitsubishi Galant 6 cyl Two Wheel Drive
My boyfriend, who has done stereos before, replaced mine. Well when he was cutting the wires he didnt disconnect the battery, he cut the last wire and i lost power to the dome light,front reading lights, cigarret lighter, and the door ajar light dosent come on when the door is open. The only way i can use the power locks is if the car is turned on with the doors closed, i cant use my keyless entry. If i try to lock the doors with the car on and the door open it imdedeately unlocks itself. When the car is off there is no power to the locks.... Please help me on this one... I have spent enough money on this car, I will never by a mitsubishi again...Thank you for your time
Mar 3, 2010 at 4:55 PM
RMCNIFF
Did you get a solution?
But I bought a used car with this issue, can you just resplice the wire?
Apr 12, 2010 at 1:56 AM
