2002 Mitsubishi Galant
2002 MITSUBISHI GALANT
NETTABUG
2002 Mitsubishi Galant 4 cyl 125000 miles
A month ago my car was leaking coolant and running hot. A pipe that leads to the radiator was replaced because it had holes in it and the radiator was flushed and filled. I never see steam coming from the car but every now and then the gauge moves toward hot. I don't see anything leaking either. Does my thermostat need to be replaced? What could be causing the gauge to move?
Jul 18, 2008 at 7:36 AM
KHLOW2008
  • 41,814 POSTS
H Nettabug,
Check if the coolant level in the radiator is correct. It could be low causing the problem.
If coolant level is correct, check if the sending switch wire is secured.
Jul 22, 2008 at 10:38 PM
