2001 wont idle
2001 MITSUBISHI GALANT
WESLEYBROCK
Engine Mechanical problem
2001 6 cyl Front Wheel Drive
my car will crank but wont run or idle unless the airconditioner is on....really confused about how to go about fixing whats wrong...
Aug 17, 2008 at 8:44 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Have the PCM scanned for codes. It may have a faulty Idle Air Control motor or circuit problem. When the A/C is on, the PCM ups the idle to compensate for the drag on the engine, if the IAC isnt working properly it may just let the car die
Aug 19, 2008 at 8:10 AM
